소개
If the blender doesn't power on, the circuit board may be damaged. This guide will show you how to replace a non-responsive circuit board.
필요한 것
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Using the Phillips #2 screwdriver remove the 4 screws (10mm long, 5mm wide) on the circuit board.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 8개
Thanks for this. Where can I locate a vendor to purchase a circuit board?
Where can I get the circuit board?
nick.nemec - 답글
Anyone had any luck on finding the circuit board to buy?
Excellent information, just need the circuit board or the schematics.
