주요 콘텐츠로 건너뛰기
Nintendo 64 Controller D-Pad Replacement
필요한 것
  1. Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 1 단계, 이미지 3개 중 1개 Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 1 단계, 이미지 3개 중 2개 Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the seven 10 mm screws from the body.
    • Remove the two 6 mm Phillips #0 screws from the expansion slot.
    • Separate the back cover from the front and set it aside.
  2. Nintendo 64 Controller D-Pad Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 64 Controller D-Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the left and right shoulder triggers by sliding them straight up.
    • Gently unhook the cable that is looped around two cable clamps by nudging it up and out.
  3. Nintendo 64 Controller D-Pad Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 64 Controller D-Pad Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 64 Controller D-Pad Replacement: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #0 screwdriver to remove the three silver 6 mm screws holding the joystick assembly in place.
    • Gently lift the motherboard and joystick assembly out of the controller.
    • In order to avoid damage to the board, lift it by the edges.
  4. Nintendo 64 Controller D-Pad Replacement: 4 단계, 이미지 3개 중 1개 Nintendo 64 Controller D-Pad Replacement: 4 단계, 이미지 3개 중 2개 Nintendo 64 Controller D-Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the rubber pad off that covers the back of the D-pad.
    • Remove the broken D-pad from its socket.
  5. Nintendo 64 Controller D-Pad Replacement: 5 단계, 이미지 3개 중 1개 Nintendo 64 Controller D-Pad Replacement: 5 단계, 이미지 3개 중 2개 Nintendo 64 Controller D-Pad Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the replacement D-pad into the socket.
    • Stretch the rubber backing onto the plastic pieces and slide it down over the D-pad.
    • Carefully reinsert the circuit board into the controller housing.
    • Insert the joystick into its opening.
  6. Nintendo 64 Controller D-Pad Replacement: 6 단계, 이미지 3개 중 1개 Nintendo 64 Controller D-Pad Replacement: 6 단계, 이미지 3개 중 2개 Nintendo 64 Controller D-Pad Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully secure the cord around the cable clamps.
    • Be sure to apply enough pressure so it sits below or flush to the edge to avoid problems putting the front and back case together.
    • Re-insert the shoulder triggers into place.
    • The L trigger will go on the right and the R trigger on the left.
    • Use a Phillips #0 screwdriver to secure the screws to the joystick assembly.
  7. Nintendo 64 Controller D-Pad Replacement: 7 단계, 이미지 2개 중 1개 Nintendo 64 Controller D-Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Snap the back cover into place.
    • Use a Phillips #0 screwdriver to replace the screws on the back cover.
결론
Happy gaming!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jamie Durman
회원 가입일: 07/01/23
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 40
전체 시간: 946
