주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo DS Lite Upper LCD Replacement
필요한 것
  1. Nintendo DS Lite Upper LCD Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Upper LCD Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Upper LCD Replacement, Lower Case: 3 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement, Lower Case: 3 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Upper LCD Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-point screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-point screws
  5. Nintendo DS Lite Upper LCD Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DS Lite Upper LCD Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DS Lite Upper LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Nintendo DS Lite Upper LCD Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Nintendo DS Lite Upper LCD Replacement, Trigger Buttons: 7 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement, Trigger Buttons: 7 단계, 이미지 2개 중 2개
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
  8. Nintendo DS Lite Upper LCD Replacement, Wi-Fi Board: 8 단계, 이미지 1개 중 1개
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DS Lite Upper LCD Replacement: 9 단계, 이미지 1개 중 1개
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
  10. Nintendo DS Lite Upper LCD Replacement: 10 단계, 이미지 1개 중 1개
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
  11. Nintendo DS Lite Upper LCD Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
  12. Nintendo DS Lite Upper LCD Replacement: 12 단계, 이미지 3개 중 1개 Nintendo DS Lite Upper LCD Replacement: 12 단계, 이미지 3개 중 2개 Nintendo DS Lite Upper LCD Replacement: 12 단계, 이미지 3개 중 3개
    • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
    • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
    • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
    • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
    • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
  13. Nintendo DS Lite Upper LCD Replacement: 13 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 13 단계, 이미지 2개 중 2개
    • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
    • Do not lift the flap more than 90 degrees, or you will break it off.
  14. Nintendo DS Lite Upper LCD Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
  15. Nintendo DS Lite Upper LCD Replacement: 15 단계, 이미지 1개 중 1개
    • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
    • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
  16. Nintendo DS Lite Upper LCD Replacement: 16 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 16 단계, 이미지 2개 중 2개
    • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
    • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
    • Remove the motherboard from the DS Lite.
    • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
  17. Nintendo DS Lite Upper LCD Replacement, Upper Case: 17 단계, 이미지 1개 중 1개
    • Remove the two 8.3 mm Phillips screws securing the upper case to the display assembly.
  18. Nintendo DS Lite Upper LCD Replacement: 18 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 18 단계, 이미지 2개 중 2개
    • Pull the upper LCD ribbon cable to the right, through the slit in the case.
    • Push the ribbon cable down through the slit.
  19. Nintendo DS Lite Upper LCD Replacement: 19 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 19 단계, 이미지 2개 중 2개
    • Slowly lift the upper case away from the display, making sure the ribbon cable does not get caught.
  20. Nintendo DS Lite Upper LCD Replacement: 20 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 20 단계, 이미지 2개 중 2개
    • Once the ribbon cable is free from the upper case, pull the antenna and Wi-Fi cables through the hole in the upper case.
    • Remove the upper case from the DS Lite.
  21. Nintendo DS Lite Upper LCD Replacement, Rear Display Bezel: 21 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement, Rear Display Bezel: 21 단계, 이미지 2개 중 2개
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  22. Nintendo DS Lite Upper LCD Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the four 3.4 mm Phillips screws securing the rear display bezel to the front display bezel
  23. Nintendo DS Lite Upper LCD Replacement: 23 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 23 단계, 이미지 2개 중 2개
    • Use the edge of a spudger to pry both rubber pads out of the front display bezel.
  24. Nintendo DS Lite Upper LCD Replacement: 24 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 24 단계, 이미지 2개 중 2개
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  25. Nintendo DS Lite Upper LCD Replacement: 25 단계, 이미지 2개 중 1개 Nintendo DS Lite Upper LCD Replacement: 25 단계, 이미지 2개 중 2개
    • Insert a spudger in the gap between the front and rear display bezels and pry the front bezel away from the rear bezel.
    • Lift the rear display bezel away from the display assembly.
  26. Nintendo DS Lite Upper LCD Replacement, Microphone: 26 단계, 이미지 3개 중 1개 Nintendo DS Lite Upper LCD Replacement, Microphone: 26 단계, 이미지 3개 중 2개 Nintendo DS Lite Upper LCD Replacement, Microphone: 26 단계, 이미지 3개 중 3개
    • Use the tip of a spudger to pry both speakers up from their housing and place them on the back of the LCD.
    • The speakers have magnets which will hold them together, helping to keep them out of the way for later steps.
  27. Nintendo DS Lite Upper LCD Replacement: 27 단계, 이미지 3개 중 1개 Nintendo DS Lite Upper LCD Replacement: 27 단계, 이미지 3개 중 2개 Nintendo DS Lite Upper LCD Replacement: 27 단계, 이미지 3개 중 3개
    • Starting in the top right corner, use both hands to slowly separate the LCD from the front display bezel.
    • Continue separating along the top and left edges of the LCD.
    • Finally, push the LCD up and away from the front display bezel.
    • Do not try to remove the LCD yet, as the LCD ribbon cable is still routed through the front display bezel.
  28. Nintendo DS Lite Upper LCD Replacement, Upper LCD: 28 단계, 이미지 1개 중 1개
    • Desolder the speakers from the upper LCD by heating up the solder joints with a soldering iron and simultaneously pulling the speaker wires away from the ribbon cable.
    • If you have never soldered before, we have a guide that makes it easy.
    • Upper LCD remains.
  29. Nintendo DS Lite Upper LCD Replacement, Threading the display ribbon: 29 단계, 이미지 1개 중 1개
    • Use a small hook to help curl the leading edge of the ribbon through the display hinge. A piece of solder like this one (shown) works well.
결론
다른 107명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
42,211 평판
안내서 67개를 작성함
10가이드 댓글
This is a very concise and accurate guide! I found this repair to be very difficult, especially so due to the aftermarket Chinese screen I installed that required me to solder on the speaker wires. Ugh! If you can, get a replacement with the speakers attached. I also can't stress enough how annoying threading the ribbon cable through the case is. DS is a great platform, but product design left a lot to be desired.
scheppdogg532 - 답글
This repair is somewhat difficult. There are a couple of points to be careful about:
1) The display ribbon cable is fairly easy to remove from the hinge, but somewhat difficult to route through it once the new display is in place. It is easier to do if the antenna/microphone wires are out of the way.
2) The ribbon connector is fairly short and difficult to manipulate so that it mates securely to the socket on the motherboard. If it isn't seated properly the DS will not boot. So test it first (by temporarily pressing the battery against the battery connectors and turning power on) before re-assembly.
Kar Wong - 답글
Make a note of where the Wi-Fi antenna connector, microphone, and speaker wires are positioned in the DS Lite housing. If they are not placed back in the correct location, the case will not close. If you force it closed you will squash the wiring which could lead to problems later on. Also be sure the speakers are placed back in correctly. If you can see metal through the speaker holes in the case then you've done it wrong (flip the speakers over). Lastly, when trying to maneuver the antenna connector back under the game cartridge reader, make sure the connector head is face down so that it does not get stuck (happened to me). If you look at the picture in Step 7, it's a straight shot from right to left when running the wire through. Use a paperclip and a flashlight to help you if you get stuck and most importantly, do not try to yank it free!
Nick G - 답글
Funny how these things give you instructions for taking things apart , but not for installing and putting back together. I found routing the screen ribbon through the hinge to be especially difficult and I think I might have damaged it in the process. I wish i would have known that its best to make sure this is done before trying lock the screen case back up.
Sebastian Lopez - 답글
This was a very difficult but fun and satisfying repair to do. The hardest part was definitely putting the display ribbon cable through the small tube to the bottom of the unit. One thing that could be done to make this easier, I would suggest having a small set of tweezers to help assist with pulling the cable through . One thing you can also do is to wrap the ribbon wire around the microphone and antenna wires a few time, then guide the orange ribbon cable about halfway out of the tube, and then attach the bottom part to it, and then pull the rest of the cable through with the tweezers. This helps a lot with preventing stress on those small, delicate cables, and can make life much easier.
The E- Scrap Man - 답글
댓글 쓰기
조회 통계:
지난 24시간: 73
지난 7일: 480
지난 30일: 3,403
전체 시간: 184,729
