주요 콘텐츠로 건너뛰기
Nintendo DSi Battery Replacement
필요한 것
  1. Nintendo DSi Battery Replacement, Battery Cover Removal: 1 단계, 이미지 2개 중 1개 Nintendo DSi Battery Replacement, Battery Cover Removal: 1 단계, 이미지 2개 중 2개
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Battery Replacement, Taking out the Battery: 2 단계, 이미지 2개 중 1개 Nintendo DSi Battery Replacement, Taking out the Battery: 2 단계, 이미지 2개 중 2개
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
결론
To reassemble your device, follow these instructions in reverse order. Take care to align the positive (+) and negative (-) connections on the battery with the console.
다른 23명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Walter Galan
706,123 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 114
지난 30일: 411
전체 시간: 33,362
