이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
소개
'이 가이드는 iFixit 직원에 의해 업데이트되었습니다! 새로운 공식 가이드 [가이드|3737|여기] 및 [가이드|3877|여기]를 읽어 보십시오.''
닌텐도 DSi 케이스 전체를 제거하는 방법에 대한 가이드.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
L Button.
Top of the battery pack.
To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
빨간색으로 강조 표시된 두 개의 고무 받침 아래에 나사 두 개가 숨겨져 있습니다.
스퍼저 끝을 사용하여 고무 받침을 하단 케이스에서 들어 올리세요.
Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
The motherboard should now be free from the rest of the device.
A/B/X/Y button assembly
Select/Start button assembly
D-pad
Power button
Flip the case open, and push the lower screen assembly out of the frame.
Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
Remove the antenna from the bottom left of the device.
Remove the microphone from the top of the frame.
Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
Push the sliding shaft completely through the hinge until it stops and the hinge is released.
The right side of bottom case should separate from the top case when you remove the sliding shaft.
Slide the top case to the right to separate the joint.
Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
To remove the speakers, place a flat object underneath and gently pry them off.
On the bottom cover, use a screwdriver to remove the 3 Phillips screws holding the battery compartment.
Removing the 2 lower screws also removes the "L" trigger.
Use a screwdriver to remove the 5 screws on the stylus holder.
Also disconnect and remove the "R" trigger button, which is held in place by two of the five stylus holder screws.
Under the stylus holder is the SD card port.
Gently lift the SD card port off the bottom cover.
Remove the metal shield and flap from under the SD card port.
This picture shows the LCD screen, battery compartment, and SD card slot (metal shield and flap) with bottom outer casing.
The complete DSi outer casing can now be replaced. Parts listed left to right: top cover, top LCD screen casing, touch LCD screen casing, and bottom cover.
Follow the guides for the replacement of the DSi components backwards with your new outer casing.
장치를 다시 조립하려면 다음 지침을 역순으로 따릅니다.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
40%
GANG “BLAESE36”님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 한 개
Pictures are too dark to properly see where the structures mentioned in the text are, but worse than this, Steps 21 and 22 do not properly explain the “twist” method that you need to use with extreme caution! This is the Achille’s heel of dismantling the device and if you’re gonna make a mistake, let this not be the one…
