주요 콘텐츠로 건너뛰기
Nintendo DSi Top LCD Screen Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Nintendo DSi Top LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Nintendo DSi Top LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. 주의: 3-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Nintendo DSi Top LCD Screen Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Nintendo DSi Top LCD Screen Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  4. Nintendo DSi Top LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
  5. Nintendo DSi Top LCD Screen Replacement, Bottom Case: 5 단계, 이미지 1개 중 1개
    • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
    • A/B/X/Y button assembly
    • Select/Start button assembly
    • D-pad
    • Power button
  6. Nintendo DSi Top LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi Top LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the plastic buttons and keep them in a safe place.
    • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
  7. Nintendo DSi Top LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Nintendo DSi Top LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Flip the case open, and push the lower screen assembly out of the frame.
  8. Nintendo DSi Top LCD Screen Replacement, Top LCD Screen: 8 단계, 이미지 1개 중 1개
    • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
    • Using a spudger, or similar tool, pry out the 4 square screw covers.
  9. Nintendo DSi Top LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove 4 Phillips screws with a #00 Phillips screwdriver.
  10. Nintendo DSi Top LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
    • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
  11. Nintendo DSi Top LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the antenna from the bottom left of the device.
    • Remove the microphone from the top of the frame.
  12. Nintendo DSi Top LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Use a spudger to pry the camera out of its place.
  13. Nintendo DSi Top LCD Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
    • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
  14. Nintendo DSi Top LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
    • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
  15. Nintendo DSi Top LCD Screen Replacement: 15 단계, 이미지 1개 중 1개
    • The right side of bottom case should separate from the top case when you remove the sliding shaft.
    • Do not pull up too far or the wire hinge may be damaged.
    • Slide the top case to the right to separate the joint.
    • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
  16. Nintendo DSi Top LCD Screen Replacement: 16 단계, 이미지 2개 중 1개 Nintendo DSi Top LCD Screen Replacement: 16 단계, 이미지 2개 중 2개
    • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
    • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
  17. Nintendo DSi Top LCD Screen Replacement: 17 단계, 이미지 1개 중 1개
    • To remove the speakers, use a spudger or a similar tool to gently pry them off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
18다른 기여자 명과 함께
rjcamero
회원 가입일: 11/05/09
50 평판
안내서 3개를 작성함
Cal Poly, Team 6-1, Maness Fall 2009 Cal Poly, Team 6-1, Maness Fall 2009 회원
CPSU-MANESS-F09S6G1
5 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 126
지난 30일: 496
전체 시간: 38,229
