주요 콘텐츠로 건너뛰기
Nintendo DSi Wi-Fi Board Replacement
필요한 것
  1. Nintendo DSi Wi-Fi Board Replacement, Battery Cover Removal: 1 단계, 이미지 2개 중 1개 Nintendo DSi Wi-Fi Board Replacement, Battery Cover Removal: 1 단계, 이미지 2개 중 2개
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Wi-Fi Board Replacement, Taking out the Battery: 2 단계, 이미지 2개 중 1개 Nintendo DSi Wi-Fi Board Replacement, Taking out the Battery: 2 단계, 이미지 2개 중 2개
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Wi-Fi Board Replacement, Lower Case Assembly: 3 단계, 이미지 2개 중 1개 Nintendo DSi Wi-Fi Board Replacement, Lower Case Assembly: 3 단계, 이미지 2개 중 2개
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Wi-Fi Board Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DSi Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DSi Wi-Fi Board Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Wi-Fi Board Replacement, Wi-Fi Board: 7 단계, 이미지 1개 중 1개
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Wi-Fi Board Replacement: 8 단계, 이미지 1개 중 1개
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
706,075 평판
안내서 1,203개를 작성함
3가이드 댓글
What causes the Wifi board to need replaced? Just age or is there a more technical explanation?
James McCurry - 답글
thank you! Easy to follow and awesome step-by-step instructions!
Belt Boy's Dad - 답글
to put it back do you need glue?
j veñ - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 75
지난 30일: 393
전체 시간: 21,567
