주요 콘텐츠로 건너뛰기
Nintendo DSi XL Left Shoulder Button Replacement
필요한 것
  1. Nintendo DSi XL Left Shoulder Button Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    rust/white powder built up on a screw and can’t unscrew it
    Eco - 답글
  2. Nintendo DSi XL Left Shoulder Button Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Left Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 2개 Nintendo DSi XL Left Shoulder Button Replacement, Lower Case: 3 단계, 이미지 3개 중 3개
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Left Shoulder Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Left Shoulder Button Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DSi XL Left Shoulder Button Replacement: 5 단계, 이미지 3개 중 3개
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Left Shoulder Button Replacement: 6 단계, 이미지 2개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement: 6 단계, 이미지 2개 중 2개
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Left Shoulder Button Replacement: 7 단계, 이미지 2개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Left Shoulder Button Replacement, Left Shoulder Button: 8 단계, 이미지 3개 중 1개 Nintendo DSi XL Left Shoulder Button Replacement, Left Shoulder Button: 8 단계, 이미지 3개 중 2개 Nintendo DSi XL Left Shoulder Button Replacement, Left Shoulder Button: 8 단계, 이미지 3개 중 3개
    • Remove the two gold 4.0 mm Phillips screws securing the left shoulder button assembly to the lower case.
    • Lift the left shoulder button assembly from the lower case.
    • The components of the left shoulder button assembly:
    • Left shoulder button
    • Shoulder button spring
    • Retaining pin
    • Left shoulder button support panel
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
129,851 평판
안내서 143개를 작성함
iFixit iFixit 회원
Staff
119 회원들
안내서 19,475개를 작성함
댓글 한 개
Wait, im looking how to actually replace the switch itself, I ordered actuall clickers from amazon. Like remove it safely from the orange strip cable and plastic. Ive searched everywhere on the web but no help.
Doggy Doggy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 22
지난 30일: 96
전체 시간: 16,502
