주요 콘텐츠로 건너뛰기
Nintendo DSi XL Speakers Replacement
필요한 것
  1. Nintendo DSi XL Speakers Replacement, Battery: 1 단계, 이미지 1/2 Nintendo DSi XL Speakers Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    rust/white powder built up on a screw and can’t unscrew it
    Eco - 답글
  2. Nintendo DSi XL Speakers Replacement: 2 단계, 이미지 1/1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Speakers Replacement, Rear Bezel: 3 단계, 이미지 1/3 Nintendo DSi XL Speakers Replacement, Rear Bezel: 3 단계, 이미지 2/3 Nintendo DSi XL Speakers Replacement, Rear Bezel: 3 단계, 이미지 3/3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  4. Nintendo DSi XL Speakers Replacement: 4 단계, 이미지 1/1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  5. Nintendo DSi XL Speakers Replacement: 5 단계, 이미지 1/2 Nintendo DSi XL Speakers Replacement: 5 단계, 이미지 2/2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  6. Nintendo DSi XL Speakers Replacement: 6 단계, 이미지 1/2 Nintendo DSi XL Speakers Replacement: 6 단계, 이미지 2/2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  7. Nintendo DSi XL Speakers Replacement: 7 단계, 이미지 1/1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  8. Nintendo DSi XL Speakers Replacement: 8 단계, 이미지 1/1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  9. Nintendo DSi XL Speakers Replacement: 9 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  10. Nintendo DSi XL Speakers Replacement, Speakers: 10 단계, 이미지 1/1
    • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
  11. Nintendo DSi XL Speakers Replacement: 11 단계, 이미지 1/1
    • Use a spudger to lift the right speaker from its housing in the front bezel.
  12. Nintendo DSi XL Speakers Replacement: 12 단계, 이미지 1/1
    • Use a spudger to lift the left speaker from its housing in the front bezel.
  13. Nintendo DSi XL Speakers Replacement: 13 단계, 이미지 1/2 Nintendo DSi XL Speakers Replacement: 13 단계, 이미지 2/2
    • De-route the left speaker cable along the top edge of the upper LCD.
  14. Nintendo DSi XL Speakers Replacement: 14 단계, 이미지 1/1
    • Open the display slightly, and lift the LCD out of the front bezel.
    • Lay the LCD down next to the DSi XL.
    • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
  15. Nintendo DSi XL Speakers Replacement: 15 단계, 이미지 1/1
    • Desolder the two solder joints to separate the speakers from the LCD.
    • Right Speaker
    • Left Speaker
    • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
    • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 01/05/10
39,500 평판
안내서 67개 작성하였습니다
댓글 3개
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - 답글
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - 답글
is there anyway of adding two more speaker?
vincent johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 24
전체 시간: 6,761
