주요 콘텐츠로 건너뛰기
Nintendo Game Boy Advance SP Screen Replacement
필요한 것
  1. Nintendo Game Boy Advance SP Screen Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 3개
    • Slide the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge in, remove it.
  2. Nintendo Game Boy Advance SP Screen Replacement, Remove the battery cover: 2 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the battery cover: 2 단계, 이미지 2개 중 2개
    • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
  3. Nintendo Game Boy Advance SP Screen Replacement: 3 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement: 3 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the edge of the cover near the screw and remove the cover.
    • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
  4. Nintendo Game Boy Advance SP Screen Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • Use your finger to lift the battery by the tab on its left edge, then remove it.
    • During reassembly:
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Your replacement battery may come with a plastic enclosure that slides over the battery.
    • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
  5. Nintendo Game Boy Advance SP Screen Replacement, Remove the bottom shell: 5 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the bottom shell: 5 단계, 이미지 2개 중 2개
    • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
    • Four 6.3 mm‑long recessed screws
    • Two 4.6 mm‑long screws
  6. Nintendo Game Boy Advance SP Screen Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the bottom shell straight up and remove it.
  7. Nintendo Game Boy Advance SP Screen Replacement, Remove the power switch cover: 7 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the power switch cover: 7 단계, 이미지 2개 중 2개
    • Use your fingers to lift and remove the power switch cover.
    • Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
    • Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
    • If the switch isn't properly in its cutout, you won't be able to power on your Game Boy.
  8. Nintendo Game Boy Advance SP Screen Replacement, Remove the motherboard screws: 8 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the motherboard screws: 8 단계, 이미지 2개 중 2개
    • Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
  9. Nintendo Game Boy Advance SP Screen Replacement, Prop up the motherboard: 9 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Prop up the motherboard: 9 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Prop up the motherboard: 9 단계, 이미지 3개 중 3개
    • Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
    • Use your fingers to gently flip the motherboard over the hinges and prop it up.
  10. Nintendo Game Boy Advance SP Screen Replacement, Remove the silicone pads: 10 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the silicone pads: 10 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the silicone pads: 10 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to remove the four silicone pads covering the buttons (A and B, D‑pad, brightness, and Start/Select).
    • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
  11. Nintendo Game Boy Advance SP Screen Replacement, Remove the buttons: 11 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the buttons: 11 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the buttons: 11 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to remove the buttons (A and B, D‑pad, brightness, and Start/Select).
    • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
  12. Nintendo Game Boy Advance SP Screen Replacement, Remove the speaker: 12 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the speaker: 12 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the speaker: 12 단계, 이미지 3개 중 3개
    • Use the point of a spudger or a clean fingernail to lift the speaker until you can grip it with your fingers.
    • Remove the speaker.
  13. Nintendo Game Boy Advance SP Screen Replacement, Prop up the main body: 13 단계, 이미지 1개 중 1개
    • Remove the circular mesh from the speaker recess and set it aside—the piece can easily fall out and get lost when working.
  14. Nintendo Game Boy Advance SP Screen Replacement, Prop up the main body: 14 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Prop up the main body: 14 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Prop up the main body: 14 단계, 이미지 3개 중 3개
    • Be careful not to strain the screen cable during the next few steps—it has very little slack.
    • You need to prop up the main body of your Game Boy in order to disconnect the screen cable without straining it. Here are two ways to do so:
    • Option 1: Open the main body of your Game Boy to a 90‑degree angle and gently lay the motherboard down. Make sure the main body is resting on top of the motherboard to give the cable slack.
    • Option 2: Keep the main body closed and prop it up on the edge of the logic board, using a sturdy object to hold it up.
  15. Nintendo Game Boy Advance SP Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Disconnect the screen cable: 15 단계, 이미지 3개 중 3개
    • Use the point of a spudger to push the two tabs on either side of the screen cable connector into the unlocked position.
    • Only push the tabs until they stop. If you push them too far, you may slide the locking tab off the connector.
  16. Nintendo Game Boy Advance SP Screen Replacement: 16 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to gently slide the screen cable out of its socket.
  17. Nintendo Game Boy Advance SP Screen Replacement, Remove the main body: 17 단계, 이미지 1개 중 1개
    • Remove the main body from the motherboard.
    • During reassembly, prop up the main body for enough slack reconnect the screen cable.
  18. Nintendo Game Boy Advance SP Screen Replacement, Open your Game Boy: 18 단계, 이미지 1개 중 1개
    • Open your Game Boy to a 90‑degree angle and set it down so the screen is facing up.
  19. Nintendo Game Boy Advance SP Screen Replacement, Remove the rubber screw covers: 19 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the rubber screw covers: 19 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the rubber screw covers: 19 단계, 이미지 3개 중 3개
    • Use a pair of angled tweezers to pry up and remove all five rubber screw covers.
    • Removing old, brittle covers without damaging them can be tricky. Make sure to pry gently between the cover’s edge and the frame—don’t dig into the cover itself.
  20. Nintendo Game Boy Advance SP Screen Replacement, Remove the screen screws: 20 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the screen screws: 20 단계, 이미지 2개 중 2개
    • Use a tri‑point Y0 screwdriver to remove the five 4.7 mm‑long screws securing screen shells together.
  21. Nintendo Game Boy Advance SP Screen Replacement, Close the main body: 21 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Close the main body: 21 단계, 이미지 2개 중 2개
    • Fully close your Game Boy (the button cutouts should be on top).
  22. Nintendo Game Boy Advance SP Screen Replacement, Remove the hinge cover screw: 22 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the hinge cover screw: 22 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the hinge cover screw: 22 단계, 이미지 3개 중 3개
    • Use a JIS 00 screwdriver to remove the 6.3 mm‑long screw securing the hinge cover.
    • You may need to use your free hand to hold the screen cable out of the way.
  23. Nintendo Game Boy Advance SP Screen Replacement, Flip your Game Boy over: 23 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Flip your Game Boy over: 23 단계, 이미지 2개 중 2개
    • Flip your Game Boy over.
  24. Nintendo Game Boy Advance SP Screen Replacement, Remove the hinge cover: 24 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the hinge cover: 24 단계, 이미지 2개 중 2개
    • Use your fingers to lift and remove the hinge cover.
  25. Nintendo Game Boy Advance SP Screen Replacement, Remove the top shell: 25 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the top shell: 25 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the top shell: 25 단계, 이미지 3개 중 3개
    • Depending on the age of your device, the screen may stay attached to its outer shell. If it does, make sure to thread the cable through its cutout while removing the shell.
    • Use your fingers to lift and remove the outer screen shell.
  26. Nintendo Game Boy Advance SP Screen Replacement, Remove the screen: 26 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Remove the screen: 26 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Remove the screen: 26 단계, 이미지 3개 중 3개
    • Use your fingers to lift and remove the screen, threading the cable through its cutout.
    • If your screen stayed attached to the shell, you may need to gently pry it up with a spudger before removing it.
    • Place the screen foam-side up into its recess, so the cable is near the hinges.
    • Make one loop in the screen cable and then slide it through the cutout.
  27. Nintendo Game Boy Advance SP Screen Replacement, Modification information: 27 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Screen Replacement, Modification information: 27 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Screen Replacement, Modification information: 27 단계, 이미지 3개 중 3개
    • For some IPS screen upgrades, you may need to make modifications to your replacement screen shell or the screen itself. If you're using the original screen, you don't need to make modifications. Check your kit or the website you purchased it from for specific instructions before making any modifications.
    • Some IPS screens are bigger than the original. You may need to use flush cutters to trim one of the side rails to make room for your replacement screen.
    • Your replacement screen may come with a small board and ribbon cable(s). The board will likely need to be adhered to the back of the screen, and the ribbon cable will connect to the board. Check the board and any cables for adhesive backings.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
155,120 평판
안내서 1,033개를 작성함
6가이드 댓글
hello can i ask something? can you take apart the lcd? because my lcd has fungus
Jorick Earl Bastian - 답글
I am pretty sure, as the actual screen can be separated from the plastic cover (the thing that says game boy advance). I’ve never seen fungus in a screen though. That’s interesting.
Lucas Hoekstra (Lucas9810) -
Hello friend! One question: in the replace screen there is retroillumination? or i have to do something? Thx for your answer!
Federico Celani - 답글
The light is built in on all GBA SPs.
there is a model with a better backlit display instead of a front lit display, but both have a light.
Heya! I was wondering if it’s possible to use an ag101 screen with an ag 001 motherboard? I’d prefer the better lit screen but ag101 models aren’t common in the uk
Sean Richardson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 32
지난 7일: 232
지난 30일: 1,066
전체 시간: 92,590
