소개
This guide will help you install the C Stick. The C Stick is the yellow joystick. This guide should be helpful if the C Stick has gone rogue.
필요한 것
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Grab the Z-button by the peg with tweezers and lift it out of the controller.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
This doesnt help by c stick is broken and i need help. Up and down work just fine on it, but it doesnt rgister left and right. Anybody have any help?
I did a mod on it and it worked fine until then but its really weird that left and right arent working but up and down are i couldve accidentally got hot glue in there... Any way to buy an entirely new c stick unit?
