주요 콘텐츠로 건너뛰기
Nintendo GameCube Fan replacement for cleaning
필요한 것
  1. Nintendo GameCube Fan replacement for cleaning, Top Case: 1 단계, 이미지 3개 중 1개 Nintendo GameCube Fan replacement for cleaning, Top Case: 1 단계, 이미지 3개 중 2개 Nintendo GameCube Fan replacement for cleaning, Top Case: 1 단계, 이미지 3개 중 3개
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Fan replacement for cleaning: 2 단계, 이미지 3개 중 1개 Nintendo GameCube Fan replacement for cleaning: 2 단계, 이미지 3개 중 2개 Nintendo GameCube Fan replacement for cleaning: 2 단계, 이미지 3개 중 3개
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Fan replacement for cleaning, Fan: 3 단계, 이미지 2개 중 1개 Nintendo GameCube Fan replacement for cleaning, Fan: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
    • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
    • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
    • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
  4. Nintendo GameCube Fan replacement for cleaning: 4 단계, 이미지 2개 중 1개 Nintendo GameCube Fan replacement for cleaning: 4 단계, 이미지 2개 중 2개
    • Once the fan is removed, use compressed air to clean the dust off of the fan blades.
    • It is highly recommended that you use a toothpick to prevent the fan blades from moving while cleaning. This will prevent accidental damage to the fans motor.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
dcarlin
회원 가입일: 11/05/09
390 평판
안내서 4개를 작성함
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 회원
CPSU-MANESS-F09S6G2
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 43
지난 30일: 177
전체 시간: 41,055
