이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn over the Gamecube so that the bottom side is facing up.
Use the 4.5 mm Gamebit screwdriver to remove all four screws.
With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
Move the GameCube so that the inside is facing upwards.
Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
Carefully disconnect the fan connector from the socket, as depicted in the second picture.
Once the fan is removed, use compressed air to clean the dust off of the fan blades.
다른 10명이 해당 안내서를 완성하였습니다.
