주요 콘텐츠로 건너뛰기
Nintendo Switch Pro Controller Joystick Caps Replacement
필요한 것
  1. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 3개
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 3개
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the clear plastic cover: 5 단계, 이미지 1개 중 1개
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: 6 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: 6 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the battery: 6 단계, 이미지 3개 중 3개
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
  7. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: 7 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: 7 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the screws: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
  8. Nintendo Switch Pro Controller Joystick Caps Replacement: 8 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement: 8 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement: 8 단계, 이미지 3개 중 3개
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
  9. Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: 9 단계, 이미지 2개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Open the flap: 9 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
  10. Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
  11. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the front case: 11 단계, 이미지 1개 중 1개
    • Remove the front case.
  12. Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Caps Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 3개
    • With light force pull the two joystick caps off of the controller.
결론
다른 32명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christian Rudnick
회원 가입일: 10/10/19
593 평판
안내서 1개를 작성함
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S11G2
5 회원들
안내서 45개를 작성함
3가이드 댓글
Where can I get the replacement caps?
Locke Valentine - 답글
do you know where to find a replacement cap? If so can you give me link, thanks!
Jesus Acosta -
You really don't need to disconnect the ZIF to replace the caps. It might make things a tiny bit easier, but is best not to mess with it AT ALL if you're only replacing the caps. As messing it up, or not connecting it properly when you're putting it back together can lead to ALL your face buttons and D-pad not working.
master2873 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 85
지난 30일: 360
전체 시간: 30,201
