소개
This guide will show you the steps on installing the motherboard. This will be helpful if the controller won't turn on or if it turns on and doesn't work.
필요한 것
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Using tweezers remove the three grey button pads from the motherboard.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
