소개
This guide will show you the steps on installing the shoulder buttons. This will be helpful if the shoulder buttons are not working properly.
Only replace the faulty shoulder button(s).
부품
지정된 부품이 없습니다.
Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
