주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii 2011 DVD Drive Replacement/Repair
필요한 것
  1. Nintendo Wii 2011 DVD Drive Replacement/Repair, DVD Drive: 1 단계, 이미지 1개 중 1개
    • Follow Nintendo Wii 2011 Outer Case Removal/Dissassemby up to step 14.
    • Begin this guide on the metal casing side of the DVD drive.
    • Steps 2-6 of this guide will walk you through attempting to move/adjust components of the drive that may have become jammed in place.
  2. Nintendo Wii 2011 DVD Drive Replacement/Repair: 2 단계, 이미지 1개 중 1개
    • Try to adjust the white plastic component found in the hole in the metal case. It should move freely, if not try to wiggle it until it does.
  3. Nintendo Wii 2011 DVD Drive Replacement/Repair: 3 단계, 이미지 1개 중 1개
    • Next, attempt to slide the white plastic component along the arch-shaped cut out in the metal case. It should move freely when the drive is open.
  4. Nintendo Wii 2011 DVD Drive Replacement/Repair: 4 단계, 이미지 1개 중 1개
    • Repeat step 3 with the identical component 2 inches above the first one.
  5. Nintendo Wii 2011 DVD Drive Replacement/Repair: 5 단계, 이미지 1개 중 1개
    • Attempt to manipulate the white plastic component shown in the photo. If it is jammed, the disc drive may have broken internal components.
  6. Nintendo Wii 2011 DVD Drive Replacement/Repair: 6 단계, 이미지 1개 중 1개
    • Flip over the DVD disc drive. Along one edge is a long white rail on gears for moving the DVD in and out of the drive. Slide it along its track, it should snap back into place. If not, there may be internal damage to the DVD drive.
  7. Nintendo Wii 2011 DVD Drive Replacement/Repair: 7 단계, 이미지 1개 중 1개
    • If none of those adjustments fix the problem with your DVD drive, you will need to replace it.
    • Follow the steps for removing the DVD drive in reverse to install a new DVD drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
1가이드 댓글
Disc read error is a common issue. To tell if the laser is faulty take the shell off of the wii and insert a disc in the drive and see if a red light comes on where the disc is spinning.
Brett J - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 126
전체 시간: 6,209
