주요 콘텐츠로 건너뛰기
Nobis NB07 Cameras Replacement
필요한 것
  1. Nobis NB07 Cameras Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Cameras Replacement: 2 단계, 이미지 3개 중 1개 Nobis NB07 Cameras Replacement: 2 단계, 이미지 3개 중 2개 Nobis NB07 Cameras Replacement: 2 단계, 이미지 3개 중 3개
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 3개 중 1개 Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 3개 중 2개 Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 3개 중 3개
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Cameras Replacement: 4 단계, 이미지 3개 중 1개 Nobis NB07 Cameras Replacement: 4 단계, 이미지 3개 중 2개 Nobis NB07 Cameras Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Cameras Replacement: 5 단계, 이미지 1개 중 1개
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Cameras Replacement: 6 단계, 이미지 2개 중 1개 Nobis NB07 Cameras Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 3개 중 1개 Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 3개 중 2개 Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 3개 중 3개
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Cameras Replacement: 8 단계, 이미지 2개 중 1개 Nobis NB07 Cameras Replacement: 8 단계, 이미지 2개 중 2개
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Cameras Replacement: 9 단계, 이미지 3개 중 1개 Nobis NB07 Cameras Replacement: 9 단계, 이미지 3개 중 2개 Nobis NB07 Cameras Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
결론
작성자
3다른 기여자 명과 함께
Daniel Gomero
회원 가입일: 01/21/15
966 평판
안내서 5개를 작성함
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 회원
USFT-BROWN-W15S5G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 11
전체 시간: 227
