주요 콘텐츠로 건너뛰기
Nobis NB07 Speaker Replacement
필요한 것
  1. Nobis NB07 Speaker Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Nobis NB07 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Nobis NB07 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Speaker Replacement, Replacing the battery: 3 단계, 이미지 3개 중 1개 Nobis NB07 Speaker Replacement, Replacing the battery: 3 단계, 이미지 3개 중 2개 Nobis NB07 Speaker Replacement, Replacing the battery: 3 단계, 이미지 3개 중 3개
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Nobis NB07 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Nobis NB07 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Nobis NB07 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Speaker Replacement, Removing the speaker: 7 단계, 이미지 3개 중 1개 Nobis NB07 Speaker Replacement, Removing the speaker: 7 단계, 이미지 3개 중 2개 Nobis NB07 Speaker Replacement, Removing the speaker: 7 단계, 이미지 3개 중 3개
    • Remove the tape holding the speaker in its socket.
  8. Nobis NB07 Speaker Replacement: 8 단계, 이미지 2개 중 1개 Nobis NB07 Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • After you remove the tape, remove the speaker from its socket. You can place the speaker on one side of the tablet to have more freedom.
    • Look for the place where the speaker's cables meet with the motherboard.
    • Annotate where which color goes to make the reassembly easier.
  9. Nobis NB07 Speaker Replacement: 9 단계, 이미지 2개 중 1개 Nobis NB07 Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Use a soldering iron to desolder the cables and extract the solder using a desoldering braid.
    • You can now remove the speaker.
결론
작성자
2다른 기여자 명과 함께
Daniel Gomero
회원 가입일: 01/21/15
966 평판
안내서 5개를 작성함
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 회원
USFT-BROWN-W15S5G5
3 회원들
안내서 10개를 작성함
2가이드 댓글
How can I restore the memory on these tablets - were having problems with this tablet please help us
annievvtait07 - 답글
This is my favourite online game mahjong games online i have some time play.
conor mcgregor - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 316
