주요 콘텐츠로 건너뛰기
Nokia 5310b XpressMusic LCD Screen Replacement
필요한 것
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 3 단계, 이미지 3개 중 1개 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 3 단계, 이미지 3개 중 2개 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: 3 단계, 이미지 3개 중 3개
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
    Before doing this step, first remove the camera cover and the two t6 screws from the back (steps 5 and 6). Otherwise you will break the cover. This may be a factor only for some revisions (RM-304)
    s c - 답글
  4. Nokia 5310b XpressMusic LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: 9 단계, 이미지 1개 중 1개
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Max Kirby
회원 가입일: 05/01/11
518 평판
안내서 4개를 작성함
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 회원
CPSU-REGAN-S11S15G14
3 회원들
안내서 8개를 작성함
1 Guide Comment
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 16
전체 시간: 9,212
