소개
Use this guide to replace your Nokia 6’s motherboard.
If the battery is swollen, take appropriate precautions. Be very careful when heating the phone when removing the screen. As the battery is in the center of the phone, avoid heating the center, focusing only on the edges to heat up the adhesive.
필요한 것
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
다른 3명이 해당 안내서를 완성하였습니다.
