주요 콘텐츠로 건너뛰기
Nokia 6085h Front LCD Display
필요한 것
  1. Nokia 6085h Front LCD Display, Battery: 1 단계, 이미지 1개 중 1개
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: 2 단계, 이미지 1개 중 1개
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: 3 단계, 이미지 3개 중 1개 Nokia 6085h Front LCD Display, Front LCD Display: 3 단계, 이미지 3개 중 2개 Nokia 6085h Front LCD Display, Front LCD Display: 3 단계, 이미지 3개 중 3개
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Front LCD Display: 4 단계, 이미지 2개 중 1개 Nokia 6085h Front LCD Display: 4 단계, 이미지 2개 중 2개
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Front LCD Display: 5 단계, 이미지 3개 중 1개 Nokia 6085h Front LCD Display: 5 단계, 이미지 3개 중 2개 Nokia 6085h Front LCD Display: 5 단계, 이미지 3개 중 3개
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Front LCD Display: 6 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Front LCD Display: 7 단계, 이미지 3개 중 1개 Nokia 6085h Front LCD Display: 7 단계, 이미지 3개 중 2개 Nokia 6085h Front LCD Display: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Brett Balcer
회원 가입일: 10/04/10
240 평판
안내서 2개를 작성함
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G46
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,302
