주요 콘텐츠로 건너뛰기
Nokia Lumia 2520 Display Assembly Replacement
필요한 것
  1. Nokia Lumia 2520 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Apply heat pad to each side of the device.
    • When using any heat pad please use some form of padded gloves so you don't burn you fingers.
    • Microwave the pad for 30 seconds so an ample amount of heat is given on all four sides. Do not microwave more than once every two minutes.
  2. Nokia Lumia 2520 Display Assembly Replacement: 2 단계, 이미지 3개 중 1개 Nokia Lumia 2520 Display Assembly Replacement: 2 단계, 이미지 3개 중 2개 Nokia Lumia 2520 Display Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
    • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
    • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
  3. Nokia Lumia 2520 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Nokia Lumia 2520 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the ribbon cable out from the connection port on the board.
    • Move on the step 4 to remove the ribbon connection from the screen.
  4. Nokia Lumia 2520 Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Nokia Lumia 2520 Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Nokia Lumia 2520 Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Use the plastic pry tool to remove both of the connections.
  5. Nokia Lumia 2520 Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Set aside the screen and the display assembly for repair.
결론
작성자
4다른 기여자 명과 함께
Daniel Chevalier
회원 가입일: 09/05/18
121 평판
안내서 1개를 작성함
Gateway, Team S1-G4, Luster Fall 2018 Gateway, Team S1-G4, Luster Fall 2018 회원
GCC-LUSTER-F18S1G4
5 회원들
안내서 5개를 작성함
1 Guide Comment
What if i clipped the ribbon cable step 2 told me not to... like in half? Springging for a new screen i assume. Ive repaired ribbons before and it doesnt look like theres enough cable left to splice.
Hunter - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 984
