주요 콘텐츠로 건너뛰기
Nook BNRV300 Back Cover Replacement
필요한 것
  1. Nook BNRV300 Back Cover Replacement, Power Button: 1 단계, 이미지 1/3 Nook BNRV300 Back Cover Replacement, Power Button: 1 단계, 이미지 2/3 Nook BNRV300 Back Cover Replacement, Power Button: 1 단계, 이미지 3/3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Back Cover Replacement: 2 단계, 이미지 1/1
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Back Cover Replacement, Back Cover: 3 단계, 이미지 1/3 Nook BNRV300 Back Cover Replacement, Back Cover: 3 단계, 이미지 2/3 Nook BNRV300 Back Cover Replacement, Back Cover: 3 단계, 이미지 3/3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Back Cover Replacement: 4 단계, 이미지 1/1
    • Slide the back cover down towards the USB port to release it. The pictures show the case being prised open but this should not be necessary.
  5. Nook BNRV300 Back Cover Replacement: 5 단계, 이미지 1/3 Nook BNRV300 Back Cover Replacement: 5 단계, 이미지 2/3 Nook BNRV300 Back Cover Replacement: 5 단계, 이미지 3/3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Back Cover Replacement: 6 단계, 이미지 1/2 Nook BNRV300 Back Cover Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Emily Tracy
회원 가입일: 10/03/19
395 평판
안내서 2개 작성하였습니다
댓글 한 개
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 31
전체 시간: 1,096
