주요 콘텐츠로 건너뛰기
Nook HD+ Charging Port Replacement
필요한 것
  1. Nook HD+ Charging Port Replacement, Motherboard: 1 단계, 이미지 1/3 Nook HD+ Charging Port Replacement, Motherboard: 1 단계, 이미지 2/3 Nook HD+ Charging Port Replacement, Motherboard: 1 단계, 이미지 3/3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Charging Port Replacement: 2 단계, 이미지 1/3 Nook HD+ Charging Port Replacement: 2 단계, 이미지 2/3 Nook HD+ Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Charging Port Replacement: 3 단계, 이미지 1/2 Nook HD+ Charging Port Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Charging Port Replacement: 4 단계, 이미지 1/1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Charging Port Replacement: 5 단계, 이미지 1/1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Charging Port Replacement: 6 단계, 이미지 1/2 Nook HD+ Charging Port Replacement: 6 단계, 이미지 2/2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Charging Port Replacement: 7 단계, 이미지 1/2 Nook HD+ Charging Port Replacement: 7 단계, 이미지 2/2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
  8. Nook HD+ Charging Port Replacement, Charging Port: 8 단계, 이미지 1/2 Nook HD+ Charging Port Replacement, Charging Port: 8 단계, 이미지 2/2
    • Once removing the motherboard, flip it over and locate the charging port. Use a soldering iron to disconnect the charging port from the motherboard. If confused here's a reference.
    • Since the charging port is attached to the motherboard, it is simpler to replace both.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device.
    • Solder the new charging port to the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bayleigh Fouts
회원 가입일: 03/31/22
97 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Where can I obtain the replacement part?? the new charging port???
Jim Rhem - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 26
전체 시간: 712
