주요 콘텐츠로 건너뛰기
Nook Simple Touch with GlowLight Screen Replacement
필요한 것
  1. Nook Simple Touch with GlowLight Screen Replacement, Power Button: 1 단계, 이미지 1개 중 1개
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Screen Replacement, Back Cover: 4 단계, 이미지 1개 중 1개
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Screen Replacement, Battery: 6 단계, 이미지 2개 중 1개 Nook Simple Touch with GlowLight Screen Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Screen Replacement, Motherboard: 7 단계, 이미지 1개 중 1개
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Screen Replacement: 8 단계, 이미지 3개 중 1개 Nook Simple Touch with GlowLight Screen Replacement: 8 단계, 이미지 3개 중 2개 Nook Simple Touch with GlowLight Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
  9. Nook Simple Touch with GlowLight Screen Replacement, Screen: 9 단계, 이미지 2개 중 1개 Nook Simple Touch with GlowLight Screen Replacement, Screen: 9 단계, 이미지 2개 중 2개
    • Insert the iFixit opening tool between the display and the front case.
    • Gently move to iFixit opening tool around the perimeter to release the set of tape strips.
  10. Nook Simple Touch with GlowLight Screen Replacement: 10 단계, 이미지 2개 중 1개 Nook Simple Touch with GlowLight Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Turn the display over. Pry the display bezel from the display assembly with the iFixit opening tool.
결론
작성자
2다른 기여자 명과 함께
Sydney Segear
회원 가입일: 03/01/23
401 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 1,059
