주요 콘텐츠로 건너뛰기
NuWave Brio 37001 Basket Handle Replacement
필요한 것
  1. NuWave Brio 37001 Basket Handle Replacement, Basket Handle: 1 단계, 이미지 1개 중 1개
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket from the NuWave's tray.
    • After removing the basket, push forward on the handle tab and pull upwards to release the basket from its casing.
  2. NuWave Brio 37001 Basket Handle Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 10 mm screws connecting the handle to the basket using a Phillips #1 screwdriver.
  3. NuWave Brio 37001 Basket Handle Replacement: 3 단계, 이미지 2개 중 1개 NuWave Brio 37001 Basket Handle Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 6 mm screws arranged in a rectangle around the handle using a Phillips #1 screwdriver.
    • Remove two 12 mm screws just below the previous four using a Phillips #1 screwdriver.
    • The two 12 mm Phillips #1 screws are in a tight spot and may be tricky to remove.
  4. NuWave Brio 37001 Basket Handle Replacement: 4 단계, 이미지 1개 중 1개
    • Separate the metal bracket from the handle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Michael Tucker
회원 가입일: 03/01/23
303 평판
안내서 2개를 작성함
1가이드 댓글
Where do you get just the replacement handle?
lucy montgomery - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 746
