주요 콘텐츠로 건너뛰기
NuWave Brio 37001 Heating Plate Replacement
필요한 것
  1. NuWave Brio 37001 Heating Plate Replacement, Heating Plate: 1 단계, 이미지 1개 중 1개
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket from the NuWave's tray.
  2. NuWave Brio 37001 Heating Plate Replacement: 2 단계, 이미지 2개 중 1개 NuWave Brio 37001 Heating Plate Replacement: 2 단계, 이미지 2개 중 2개
    • Rest your appliance upside down, with the digital screen facing your work surface.
    • Take caution in flipping your appliance. Excessive force may cause components to break.
    • Remove the six 12 mm screws located around the edge of the bottom lid using a Phillips #1 screwdriver.
    • Remove four 10 mm screws using a Phillips #1 screwdriver.
  3. NuWave Brio 37001 Heating Plate Replacement: 3 단계, 이미지 3개 중 1개 NuWave Brio 37001 Heating Plate Replacement: 3 단계, 이미지 3개 중 2개 NuWave Brio 37001 Heating Plate Replacement: 3 단계, 이미지 3개 중 3개
    • Use your finger to flip up each small metal tab located around the heating plate.
    • The plate may fall when all tabs have been flipped up.
    • Photos #2 and #3 both display an additional piece removed, which lines the edge of the basket area. Removing this is entirely unnecessary and included solely for the visibility of this guide.
  4. NuWave Brio 37001 Heating Plate Replacement: 4 단계, 이미지 1개 중 1개
    • After flipping each tab, remove the plate by pushing downwards on its surface.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Michael Tucker
회원 가입일: 03/01/23
303 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 615
