주요 콘텐츠로 건너뛰기
NuWave Brio 37001 Rubber Feet Replacement
  1. NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: 1 단계, 이미지 2개 중 1개 NuWave Brio 37001 Rubber Feet Replacement, Rubber Feet: 1 단계, 이미지 2개 중 2개
    • Unplug your NuWave appliance and ensure it has not been used within the last 20 minutes so that it is properly cooled down. Following this guide with an appliance that is still hot or powered on may result in injury.
    • Remove the basket, and flip the air fryer upside down so its feet are accessible.
  2. NuWave Brio 37001 Rubber Feet Replacement: 2 단계, 이미지 2개 중 1개 NuWave Brio 37001 Rubber Feet Replacement: 2 단계, 이미지 2개 중 2개
    • Using gentle force, pull out the damaged leg or legs.
    • If you are unsure which leg or legs need replacement, try flipping the air fryer back over again. If the legs are uneven, the air fryer will rock diagonally. The bad leg is one of the two corners that go up and down when it rocks.
    • If you still have the original packaging, the air fryer may have come with a sachet of replacement feet.
결론
If your Air Fryer is still unbalanced, identify the additional bad leg and repeat the process!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ian Moore
회원 가입일: 03/01/23
115 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 15
전체 시간: 230
