주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Battery Assembly Replacement
필요한 것
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 1개 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 2개 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: 1 단계, 이미지 3개 중 3개
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 1개 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: 2 단계, 이미지 2개 중 2개
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 1개 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 2개 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: 3 단계, 이미지 3개 중 3개
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: 4 단계, 이미지 1개 중 1개
    • Pull the battery apparatus out once all cables are removed.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Andrew Barbanera
회원 가입일: 09/20/14
376 평판
안내서 2개를 작성함
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개를 작성함
5가이드 댓글
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - 답글 공유
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - 답글 공유
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - 답글 공유
hi! how is this holding up nowadays? i found my old nvidia shield in storage recently and the batteries are completely dead ;;
Canvas - 공유
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 26
지난 30일: 94
전체 시간: 7,370
