이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Once uncovered, you can see that the battery takes up the most real-estate inside of the device. The battery is very securely glued in so you will need to be forceful but also extremely careful when removing it.
필요한 것
Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 7개
Cannot find a replacement battery anywhere, any information would be appreciated.
Thanks!
Carl
Here: to aliexpress
I just happened to be looking because my battery life is atrocious. And here's the forum where I found it. They have other links too if you want to try them out.
I just happened to be looking into this myself. I found a forum with many links that can be found by searching “Finding Replacement Battery in 2017?” . The thread is on XDA-developers.com. This is a link that works: on de.aliexpress.com
Good luck. As there is no convincing upgrade from the Shield K1, I might do this too. Other people noted that you need the little PCB attached to the original battery to solder it onto the bare replacement battery.
