주요 콘텐츠로 건너뛰기
Olympus FE-170 Motherboard Replacement
필요한 것
  1. Olympus FE-170 Motherboard Replacement, Casing: 1 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement, Casing: 1 단계, 이미지 2/2
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Olympus FE-170 Motherboard Replacement: 2 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 2 단계, 이미지 2/2
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Olympus FE-170 Motherboard Replacement: 3 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Olympus FE-170 Motherboard Replacement: 4 단계, 이미지 1/1
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Olympus FE-170 Motherboard Replacement: 5 단계, 이미지 1/1
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Olympus FE-170 Motherboard Replacement: 6 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 6 단계, 이미지 2/2
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Olympus FE-170 Motherboard Replacement: 7 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 7 단계, 이미지 2/2
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Olympus FE-170 Motherboard Replacement: 8 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 8 단계, 이미지 2/2
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  9. Olympus FE-170 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/3 Olympus FE-170 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/3 Olympus FE-170 Motherboard Replacement, Motherboard: 9 단계, 이미지 3/3
    • Remove the three screws holding the outer circuit board in place.
  10. Olympus FE-170 Motherboard Replacement: 10 단계, 이미지 1/2 Olympus FE-170 Motherboard Replacement: 10 단계, 이미지 2/2
    • Use the spudger or your fingers to remove the outer circuit board from the camera.
  11. Olympus FE-170 Motherboard Replacement: 11 단계, 이미지 1/3 Olympus FE-170 Motherboard Replacement: 11 단계, 이미지 2/3 Olympus FE-170 Motherboard Replacement: 11 단계, 이미지 3/3
    • Use the spudger to pull the plastic tabs shown off of the motherboard.
    • Gently pull the plastic piece off of the motherboard.
  12. Olympus FE-170 Motherboard Replacement: 12 단계, 이미지 1/3 Olympus FE-170 Motherboard Replacement: 12 단계, 이미지 2/3 Olympus FE-170 Motherboard Replacement: 12 단계, 이미지 3/3
    • Remove the screws shown using the 00 philips screwdriver.
  13. Olympus FE-170 Motherboard Replacement: 13 단계, 이미지 1/3 Olympus FE-170 Motherboard Replacement: 13 단계, 이미지 2/3 Olympus FE-170 Motherboard Replacement: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the pointed end of the spudger to release the ribbon cable clasp.
    • Remove the ribbon cable from the port using the tweezers.
  14. Olympus FE-170 Motherboard Replacement: 14 단계, 이미지 1/1
    • Use the tweezers to remove the ribbon cable near the shutter button.
  15. Olympus FE-170 Motherboard Replacement: 15 단계, 이미지 1/1
    • Next unsolder the connections shown.
    • See our soldering guide for help on how to unsolder
    • Soldering irons are hot, and will also heat the connection wire. Using the tweezers will protect your fingers from the heat.
  16. Olympus FE-170 Motherboard Replacement: 16 단계, 이미지 1/3 Olympus FE-170 Motherboard Replacement: 16 단계, 이미지 2/3 Olympus FE-170 Motherboard Replacement: 16 단계, 이미지 3/3
    • Gently pull the motherboard (from the bottom first) away from the device.
결론
Tyler Hartwig
회원 가입일: 03/24/15
337 평판
안내서 3개 작성하였습니다
Baylor, Team 6-4, Shaver Spring 2015 Baylor, Team 6-4, Shaver Spring 2015 회원
BU-SHAVER-S15S6G4
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 14
전체 시간: 376
