주요 콘텐츠로 건너뛰기
OnHub Congestion-sensing Antenna Replacement
필요한 것
  1. OnHub Congestion-sensing Antenna Replacement, Speaker Grille: 1 단계, 이미지 1/2 OnHub Congestion-sensing Antenna Replacement, Speaker Grille: 1 단계, 이미지 2/2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Congestion-sensing Antenna Replacement: 2 단계, 이미지 1/1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Congestion-sensing Antenna Replacement: 3 단계, 이미지 1/2 OnHub Congestion-sensing Antenna Replacement: 3 단계, 이미지 2/2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
  4. OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: 4 단계, 이미지 1/2 OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: 4 단계, 이미지 2/2
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joseph Ainsworth
회원 가입일: 02/10/16
544 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-3, Sullivan Spring 2016 USF Tampa, Team 3-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 343
