주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OneLink Safe and Sound Bluetooth Module Replacement
필요한 것
  1. OneLink Safe and Sound Bluetooth Module Replacement, Cover: 1 단계, 이미지 2개 중 1개 OneLink Safe and Sound Bluetooth Module Replacement, Cover: 1 단계, 이미지 2개 중 2개
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Bluetooth Module Replacement: 2 단계, 이미지 2개 중 1개 OneLink Safe and Sound Bluetooth Module Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Bluetooth Module Replacement: 3 단계, 이미지 2개 중 1개 OneLink Safe and Sound Bluetooth Module Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Bluetooth Module Replacement: 4 단계, 이미지 1개 중 1개
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Bluetooth Module Replacement: 5 단계, 이미지 2개 중 1개 OneLink Safe and Sound Bluetooth Module Replacement: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Bluetooth Module Replacement, Bluetooth Module: 6 단계, 이미지 1개 중 1개
    • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
  7. OneLink Safe and Sound Bluetooth Module Replacement: 7 단계, 이미지 2개 중 1개 OneLink Safe and Sound Bluetooth Module Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the Bluetooth module off of the daughterboard.
    • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
결론
작성자
4다른 기여자 명과 함께
Arianna Roberts
회원 가입일: 11/10/22
687 평판
안내서 6개를 작성함
UMass Dartmouth, Team 2-2, Petersen Fall 2022 UMass Dartmouth, Team 2-2, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 19
전체 시간: 342
