주요 콘텐츠로 건너뛰기
OnePlus 3 Daughterboard Replacement
필요한 것
  1. OnePlus 3 Daughterboard Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM eject tool, bit, or straightened paperclip into the hole located between the SIM card slot and the power button.
    • Press firmly to eject the SIM card tray.
    • During reinstallation, make sure that the SIM card tray is properly oriented. It fits in only one direction.
  2. OnePlus 3 Daughterboard Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • Remove the two 2.6 mm T2 screws from the bottom edge of the phone.
  3. OnePlus 3 Daughterboard Replacement: 3 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 3 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 3 단계, 이미지 3개 중 3개
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following three steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the screen and the body of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. It is recessed into the back cover. Only pry at this seam.
    • There are fourteen clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 3 Daughterboard Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 4 단계, 이미지 3개 중 3개
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
    • Do not use metal tools, as they will most likely crack the screen.
  5. OnePlus 3 Daughterboard Replacement: 5 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 5 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 5 단계, 이미지 3개 중 3개
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 3 Daughterboard Replacement: 6 단계, 이미지 2개 중 1개 OnePlus 3 Daughterboard Replacement: 6 단계, 이미지 2개 중 2개
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the alert switch is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  7. OnePlus 3 Daughterboard Replacement: 7 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 7 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 7 단계, 이미지 3개 중 3개
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • Lift the screen up and remove it.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  8. OnePlus 3 Daughterboard Replacement, OnePlus 3 Battery Disconnect: 8 단계, 이미지 2개 중 1개 OnePlus 3 Daughterboard Replacement, OnePlus 3 Battery Disconnect: 8 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket, located above the top right corner of the battery pack.
    • Bend the connector away from the socket to prevent accidental contact.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. OnePlus 3 Daughterboard Replacement, OnePlus 3 Interconnect Cable Disconnect: 9 단계, 이미지 2개 중 1개 OnePlus 3 Daughterboard Replacement, OnePlus 3 Interconnect Cable Disconnect: 9 단계, 이미지 2개 중 2개
    • Remove the 3 mm Phillips screw securing the cable bracket.
    • Remove the cable bracket.
  10. OnePlus 3 Daughterboard Replacement: 10 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 10 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 10 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the motherboard, which is located above the battery.
    • Repeat the process to disconnect the daughterboard flex cable from the motherboard.
  11. OnePlus 3 Daughterboard Replacement, Daughterboard: 11 단계, 이미지 2개 중 1개 OnePlus 3 Daughterboard Replacement, Daughterboard: 11 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the daughterboard, which is located below the battery.
  12. OnePlus 3 Daughterboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the interconnect flex cable.
  13. OnePlus 3 Daughterboard Replacement: 13 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 13 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 13 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the capacitative buttons connector from its socket on the daughterboard, which is located below the battery.
    • Repeat the process to disconnect the fingerprint scanner connector from its socket on the daughterboard.
  14. OnePlus 3 Daughterboard Replacement: 14 단계, 이미지 2개 중 1개 OnePlus 3 Daughterboard Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the point of a spudger underneath the antenna interconnect cable and pry up, disconnecting it from the daughterboard.
  15. OnePlus 3 Daughterboard Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the seven Phillips screws securing the daughterboard to the frame:
    • Two 3 mm black screws
    • Five 2.9 mm silver screws
  16. OnePlus 3 Daughterboard Replacement: 16 단계, 이미지 3개 중 1개 OnePlus 3 Daughterboard Replacement: 16 단계, 이미지 3개 중 2개 OnePlus 3 Daughterboard Replacement: 16 단계, 이미지 3개 중 3개
    • The daughterboard is still held in place by two plastic clips.
    • Slide the flat end of a spudger underneath the loudspeaker vent and gently twist the spudger until the daughterboard is freed from its clips.
  17. OnePlus 3 Daughterboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the daughterboard.
    • To reinstall the daughterboard, place one of the side edges to the phone, the press the other side down until the daughterboard clicks into place.
    • If the daughterboard does not easily click into place, make sure there are no flex cables or antenna cables trapped underneath it.
결론
Repair didn’t go as planned? Check out our OnePlus 3 Answers community for troubleshooting help.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
310,253 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 1,909
