주요 콘텐츠로 건너뛰기
OnePlus 6T Front Camera Replacement
필요한 것
  1. OnePlus 6T Front Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Front Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Front Camera Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 6T Front Camera Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 6T Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Front Camera Replacement, Front Camera: 5 단계, 이미지 2개 중 1개 OnePlus 6T Front Camera Replacement, Front Camera: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Front Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Front Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
100,314 평판
안내서 258개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,781개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 1,484
