이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the screen on your OnePlus 6T is scratched or malfunctioning, it may be time to replace it. This guide will help you replace the LCD touch screen on your OnePlus 6T.
필요한 것
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
이 단계에 사용된 도구:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Pay close attention to count of screws and make sure they are all removed! Always remember to look for screws hidden with stickers or labels on top of them! A safe habit to form is, double check, then double check again!
proceed with removing all visible screws located anywhere above the battery, with the exception of the two on the left of the battery (the power button housing).
Disconnect the battery from the phone by lifting the battery connector from the phone with a spudger.
placing a pick or spudger into silver slot, to the left of the camera, along the phones edge, gently pry up until the upper housing is released. then with another card or pick, continue to other end and remove the housing. remember this should require very little strength, if it fights you, double check all screws have been removed.
Using a spudger, disconnect the screen by carefully lifting the screen connector.
Remove the display from the phone.
ALWAYS remember to thoroughly and gently clean the surfaces and remove any and all remaining or leftover old adhesive. this is a crucial step in assuring that your new adhesives "bond" properly and securely to provide adequate adhering, as well as to keep any dust or dirt and other undesired subjects from entering the device.
다른 23명이 해당 안내서를 완성하였습니다.
댓글 6개
skipped a step removing the plate around the camera. It should be after step 6 and before step 7.
otherwise this guide is meh. its okay. it gets the job done, I guess.
Billieving - 답글
I only have a broken front glass on my 1+6t the screen seems ok what differences are there and where do I get a good quality front glass for it. I have never disassembled a phone before but I know a bit about electronics and know how to put computers together and I don't think it is worth me paying a third of the phon's cost for a whole screen and/or pay someone to repair it
step 9 was kinda implossible for me, even though i used alcohol and heat before.. had to dig my Jimmy under the broken corner (top left), cracked some of my screen and was somehow able to lift the screen far enough to get under it.. im also missing some detailed instructions of the reassembly, had to watch a video for this
My phone fell down and has a black screen. The screen has no cracks at all. And the phone is working too as I am able to hear the notifications and incoming calls. So any idea how much it would cost to repair it?
