소개
Mit dieser Anleitung kannst du den Akku deines OnePlus 7 Pro tauschen.
필요한 것
1 단계 OnePlus 7 Pro Akkuabdeckung
주의: 1-8 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Drücke das SIM-Auswurfwerkzeug (oder eine aufgebogene Büroklammer) vorsichtig in das kleine Loch auf der linken Seite der Oberkante.
Drücke das SIM-Auswurfwerkzeug hinein, um den SIM-Einschub auszuwerfen.
Enterferne den SIM-Einschub vom Gerät.
Entferne alle 14 Schrauben der oberen Platte.
Sind alle Schrauben entfernt, kannst du mit Platte mit dem "Spudger Tool" abnehmen.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 6개
It didnt mention how to open the back cover in the first place? Which is the hardest part and the one that require the most skills and specialized tools.
The article links another article talking about the cover. Both do not cover how to apply the new part, specifically, how to install the new battery in this case. I think vitally important. :) @fabianjung
Update: 7/10. Taking the back off went easily/smoothly after lying on a 3D printer bed (@80C) for about 10mins, then using a hot air gun (@90C) and a metal spudger and plastic picks to gently break the adhesive holding the back to the body.
No issue removing the inside cover and pulling out the battery.
Having a replacement adhesive gasket/tape is a good idea when re-assembling though. The original guide didn't mentioned this.
