주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 7 Pro Battery Replacement
필요한 것
  1. OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 3개 중 1개 OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 3개 중 2개 OnePlus 7 Pro Battery Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 3개 중 3개
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Battery Replacement: 2 단계, 이미지 2개 중 1개 OnePlus 7 Pro Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Battery Replacement: 3 단계, 이미지 3개 중 1개 OnePlus 7 Pro Battery Replacement: 3 단계, 이미지 3개 중 2개 OnePlus 7 Pro Battery Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Battery Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 7 Pro Battery Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 7 Pro Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Battery Replacement: 5 단계, 이미지 2개 중 1개 OnePlus 7 Pro Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Battery Replacement: 6 단계, 이미지 3개 중 1개 OnePlus 7 Pro Battery Replacement: 6 단계, 이미지 3개 중 2개 OnePlus 7 Pro Battery Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Battery Replacement: 8 단계, 이미지 2개 중 1개 OnePlus 7 Pro Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Peel off the adhesive cover for the new battery cover.
  9. OnePlus 7 Pro Battery Replacement, Remove upper plate: 9 단계, 이미지 1개 중 1개
    • Remove all 14 screws of the upper plate.
    • As soon as all screws are removed, you can take it off with a spudger.
    • One screw is placed underneath a white sticker. You can punch through the sticker with your screwdriver.
    • All of the screws are the same length, and can be removed with a PH00 bit.
  10. OnePlus 7 Pro Battery Replacement, Disconnect Battery: 10 단계, 이미지 1개 중 1개
    • Disconnect the battery connector with a spudger.
  11. OnePlus 7 Pro Battery Replacement: 11 단계, 이미지 2개 중 1개 OnePlus 7 Pro Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Grab the tab and gently pull the Battery out.
    • The Battery is glued on the bottom side.
    • After installing the new battery and reassembling your device, calibration is highly recommended. To calibrate the battery, charge the phone to full and allow it to continue charging uninterrupted for 2 hours, let the battery drain fully, and charge it to full without interruption one last time.
    • This step helps the phone recognize the new battery and to determine its' maximum capacity.
결론
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
다른 24명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
4다른 기여자 명과 함께
Fabian Jung
회원 가입일: 01/29/22
829 평판
안내서 1개를 작성함
10가이드 댓글
It didnt mention how to open the back cover in the first place? Which is the hardest part and the one that require the most skills and specialized tools.
Abdulaziz Alsaqer - 답글 공유
The article links another article talking about the cover. Both do not cover how to apply the new part, specifically, how to install the new battery in this case. I think vitally important. :) @fabianjung
Chintan Pathak - 답글 공유
DO NOT use the jimmy tool or anything metal to scrape the glue off!!! You will scratch and remove the paint on the back cover!
Dani - 답글 공유
5/10 as a guide IMHO.
Why isn't a replacement adhesive gasket part of the requirements (in addition to the replacement battery)??!
The seal will most likely be severely compromised after being opened.
JayM - 답글 공유
Update: 7/10. Taking the back off went easily/smoothly after lying on a 3D printer bed (@80C) for about 10mins, then using a hot air gun (@90C) and a metal spudger and plastic picks to gently break the adhesive holding the back to the body.
No issue removing the inside cover and pulling out the battery.
Having a replacement adhesive gasket/tape is a good idea when re-assembling though. The original guide didn't mentioned this.
JayM - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 107
지난 30일: 531
전체 시간: 45,759
