소개
Use this guide to replace a broken rear glass on your OnePlus 7T.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
Apply a heated iOpener to the rear glass for two minutes to loosen the adhesive beneath.
Apply a suction handle to the right edge of the rear glass.
Pull on the suction handle to create a gap between the rear glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the edge to the bottom right corner.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
다른 2명이 해당 안내서를 완성하였습니다.
