주요 콘텐츠로 건너뛰기
OnePlus 8T Screen Replacement
필요한 것
  1. OnePlus 8T Screen Replacement, Step 1  Remove the SIM tray: 1 단계, 이미지 1개 중 1개
    • Before you begin, switch off your phone
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the bottom right edge of the phone.
    • Press firmly to eject the tray
    • Remove sim card tray
  2. OnePlus 8T Screen Replacement, Heat the rear glass: 2 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  3. OnePlus 8T Screen Replacement, Create a gap: 3 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Create a gap: 3 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Create a gap: 3 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  4. OnePlus 8T Screen Replacement, Slice the adhesive: 4 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 4 단계, 이미지 2개 중 2개
    • Insert a second opening under the bottom left corner.
    • Slide the opening pick along the bottom edge to the bottom right corner.
    • Leave the pick in its place to prevent the adhesive from resealing.
  5. OnePlus 8T Screen Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Slice the adhesive: 5 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick under the bottom right corner.
    • Slide the opening pick along the right edge to the top right corner.
    • Leave the opening picks in their place to prevent the adhesive from resealing.
  6. OnePlus 8T Screen Replacement, Slice the adhesive: 6 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 6 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the top left corner to cut the adhesive.
  7. OnePlus 8T Screen Replacement, Slice the remaining adhesive: 7 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Slice the remaining adhesive: 7 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Slice the remaining adhesive: 7 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick under the top left corner.
    • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
  8. OnePlus 8T Screen Replacement, Remove the rear glass: 8 단계, 이미지 1개 중 1개
    • Remove the rear glass.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. OnePlus 8T Screen Replacement, Unscrew the motherboard cover: 9 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
  10. OnePlus 8T Screen Replacement, Unclip the motherboard cover: 10 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Unclip the motherboard cover: 10 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Unclip the motherboard cover: 10 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the bottom left corner of the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that hold it in place.
  11. OnePlus 8T Screen Replacement, Remove the motherboard cover: 11 단계, 이미지 1개 중 1개
    • Remove the motherboard cover.
  12. OnePlus 8T Screen Replacement, Disconnect the battery: 12 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Disconnect the battery: 12 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  13. OnePlus 8T Screen Replacement, Unscrew the daughterboard cover: 13 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the seven 3.8 mm-long screws securing the daughterboard cover.
  14. OnePlus 8T Screen Replacement, Remove the daughterboard cover: 14 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Remove the daughterboard cover: 14 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Remove the daughterboard cover: 14 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick under the top edge of the daughterboard cover.
    • Remove the daughterboard cover.
  15. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: 15 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: 15 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the first fingerprint sensor connector by prying it straight up from its socket.
  16. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: 16 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: 16 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the second fingerprint sensor connector by prying it straight up from its socket.
  17. OnePlus 8T Screen Replacement, Disconnect the interconnect cable: 17 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Disconnect the interconnect cable: 17 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  18. OnePlus 8T Screen Replacement, Disconnect the antenna cables: 18 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Disconnect the antenna cables: 18 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Disconnect the antenna cables: 18 단계, 이미지 3개 중 3개
    • Carefully disconnect the two antenna cables by prying them straight up from the daughterboard.
  19. OnePlus 8T Screen Replacement, Unscrew the daughterboard: 19 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 3.1 mm-long screw securing the daughterboard.
  20. OnePlus 8T Screen Replacement, Separate the daughterboard: 20 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Separate the daughterboard: 20 단계, 이미지 2개 중 2개
    • Use an opening pick to pry up the daughterboard.
    • Use your fingers to separate the daughterboard from the phone assembly.
  21. OnePlus 8T Screen Replacement, Disconnect the screen: 21 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Disconnect the screen: 21 단계, 이미지 2개 중 2개
    • Use the flat edge of a spudger to pry up and disconnect the screen connector from its socket at the frame.
  22. OnePlus 8T Screen Replacement, Heat the screen: 22 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  23. OnePlus 8T Screen Replacement, Create a gap: 23 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Create a gap: 23 단계, 이미지 2개 중 2개
    • Apply a suction cup to the right edge of the screen.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull the suction cup up with strong, steady force to create a gap.
    • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
  24. OnePlus 8T Screen Replacement, Slice the adhesive: 24 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 24 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Slice the adhesive: 24 단계, 이미지 3개 중 3개
    • Insert a second opening pick at the bottom right corner.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
  25. OnePlus 8T Screen Replacement, Slice the adhesive: 25 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 25 단계, 이미지 2개 중 2개
    • Slide the opening pick along the bottom edge to the bottom left corner to slice the adhesive.
    • Leave the pick in its place to prevent then adhesive from resealing.
  26. OnePlus 8T Screen Replacement, Slice the adhesive: 26 단계, 이미지 3개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 26 단계, 이미지 3개 중 2개 OnePlus 8T Screen Replacement, Slice the adhesive: 26 단계, 이미지 3개 중 3개
    • Insert a fourth opening pick under the bottom left corner.
    • Slide the opening pick along the left edge to the top left corner to slice the adhesive.
  27. OnePlus 8T Screen Replacement, Slice the adhesive: 27 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Slice the adhesive: 27 단계, 이미지 2개 중 2개
    • Slide the opening pick along the top edge to the top right corner.
    • When you slice near the front facing camera, insert only the tip (5 mm) of the opening pick to avoid damaging the camera.
    • Do not remove the screen completely yet. The display cable is still threaded through the midframe.
  28. OnePlus 8T Screen Replacement, Separate the screen: 28 단계, 이미지 2개 중 1개 OnePlus 8T Screen Replacement, Separate the screen: 28 단계, 이미지 2개 중 2개
    • Thread the display flex cable through the gap in the frame.
  29. OnePlus 8T Screen Replacement, Remove the screen: 29 단계, 이미지 1개 중 1개
    • Remove the screen.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
62,539 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
6가이드 댓글
Thank you iFixit & Adriana! These intructions are spot on and guided me perfectly through a successful front and rear screen replacement.
Jim M.
Jim Malinak - 답글
Hi Jim, we're happy to hear that we were able to help you with your repair!
Adriana Zwink -
I broke my phone one plus 8T just now, how should i proceed next ? I want it really to be fixed but not sure if its still in a condition that i can be repaired
Akshay Raina - 답글
Do you remove the front earpiece speaker grill as well when you remove the front screen? As I am putting the screen back on, not sure if the top of the screen needs to be under the grill, but for some reason, it isn't matching or it's bulging from that area.
Erik Stejanko - 답글
WARNING!
You have to remove the sim card tray before removing the daughterboard. At nno point in this guide is this mentioned. You risk damaging the daughterboard when trying to pry it loose.
Staffan Näs - 답글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 76
지난 30일: 329
전체 시간: 31,037
