주요 콘텐츠로 건너뛰기
OnePlus Nord N200 I/O Board Replacement
필요한 것
  1. OnePlus Nord N200 I/O Board Replacement, Back Cover: 1 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement, Back Cover: 1 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement, Back Cover: 1 단계, 이미지 3/3
    • Due to its surface, the suction tool won't hold onto the phone's rear glass. A thin slicing tool is required.
    • Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
    • This may require some force.
    • Leave the Jimmy in place for a few seconds to prevent the adhesive from resealing.
  2. OnePlus Nord N200 I/O Board Replacement: 2 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 2 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 2 단계, 이미지 3/3
    • Insert an iFixit opening pick into the gap you created with the Jimmy.
    • Slide the Jimmy around the phone to slice the adhesive.
    • Insert a second iFixit opening pick at the spot you have sliced open to keep it open.
  3. OnePlus Nord N200 I/O Board Replacement: 3 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 3 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 3 단계, 이미지 3/3
    • Slide the iFixit opening pick along the top edge to slice the adhesive.
    • Start prying the back plate off the phone.
  4. OnePlus Nord N200 I/O Board Replacement: 4 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 4 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 4 단계, 이미지 3/3
    • Remove the back cover.
  5. OnePlus Nord N200 I/O Board Replacement, Midframe: 5 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement, Midframe: 5 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement, Midframe: 5 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the sixteen 3.6 mm-long screws securing the midframe.
    • The orange circle represents a hidden screw that also needs to be screwed out. (At first glance it may not look like a screw).
  6. OnePlus Nord N200 I/O Board Replacement: 6 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 6 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 6 단계, 이미지 3/3
    • Gently insert the Jimmy to create a gap between the midframe and the top of components in the bottom case.
    • Slide an opening pick around the edge of the midframe to slice the adhesive.
    • Use the Jimmy to pry off the midframe of the phone.
  7. OnePlus Nord N200 I/O Board Replacement: 7 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 7 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 7 단계, 이미지 3/3
    • Use your hands to finish prying open the midframe off the phone.
    • Watch out for the fingerprint reader cable when taking off the back tray as it is still connected. If you are not careful, it could be damaged.
    • Pull the midframe off of the phone and lay it to the side of the phone.
  8. OnePlus Nord N200 I/O Board Replacement: 8 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 8 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 8 단계, 이미지 3/3
    • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect the fingerprint cable connector.
    • Move the fingerprint reader cable to the side along with the midframe.
  9. OnePlus Nord N200 I/O Board Replacement: 9 단계, 이미지 1/1
    • Remove the midframe.
  10. OnePlus Nord N200 I/O Board Replacement, OnePlus Nord N200 Battery Connector Replacement: 10 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement, OnePlus Nord N200 Battery Connector Replacement: 10 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement, OnePlus Nord N200 Battery Connector Replacement: 10 단계, 이미지 3/3
    • Before you start with the repair, make sure to disconnect the battery from the charger to avoid damaging your phone.
    • Place a spudger or an opening pick under the connector's edge and pry straight up to disconnect the battery.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • Don't press down on the middle of wider connectors until they're fully seated. If misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
  11. OnePlus Nord N200 I/O Board Replacement, Speaker: 11 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement, Speaker: 11 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement, Speaker: 11 단계, 이미지 3/3
    • Insert iFixit opening pick under speaker assembly.
    • Lift up the iFixit opening pick to pull out the speaker assembly out of its tray.
    • The speaker assembly should come out easily. If not, check if you missed a screw.
  12. OnePlus Nord N200 I/O Board Replacement: 12 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 12 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 12 단계, 이미지 3/3
    • Remove the speaker assembly.
  13. OnePlus Nord N200 I/O Board Replacement, I/O Board: 13 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement, I/O Board: 13 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement, I/O Board: 13 단계, 이미지 3/3
    • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect the battery.
  14. OnePlus Nord N200 I/O Board Replacement: 14 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 14 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 14 단계, 이미지 3/3
    • To disconnect the black coaxial cable connector, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck (as close to the head as possible) and lift straight up from the board.
    • Start with the black coaxial connector as it is safer to disconnect first.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
  15. OnePlus Nord N200 I/O Board Replacement: 15 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 15 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 15 단계, 이미지 3/3
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the white coaxial cable connector (as close to the head as possible) and lift straight up from the board.
    • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
  16. OnePlus Nord N200 I/O Board Replacement: 16 단계, 이미지 1/3 OnePlus Nord N200 I/O Board Replacement: 16 단계, 이미지 2/3 OnePlus Nord N200 I/O Board Replacement: 16 단계, 이미지 3/3
    • Insert the iFixit opening pick under either side of the I/O board.
    • Use the opening pick or a spudger to pry under the I/O board and remove it from the case.
  17. OnePlus Nord N200 I/O Board Replacement: 17 단계, 이미지 1/2 OnePlus Nord N200 I/O Board Replacement: 17 단계, 이미지 2/2
    • Remove the I/O board.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Fabrise Niyonkuru
회원 가입일: 03/18/24
1,069 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team 1-1, Konn Spring 2024 UMass Dartmouth, Team 1-1, Konn Spring 2024 회원
UMASSD-KONN-S24S1G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 36
