소개
Is your phone experiencing frequent crashes or failing to boot up, suggesting a possible issue with the motherboard? If so, here's your guide to replacing the faulty motherboard and restoring your device's functionality. You'll need a set of precision tools and a replacement motherboard compatible with your phone model.
This guide shows how to replace the motherboard in the OnePlus Nord N200, model number DE2118. This guide will provide you with the essential steps to safely remove and replace the motherboard, the central component that integrates the main functionalities of your device.
Indications that the motherboard may need to be replaced include: Persistent software issues that do not resolve with a factory reset, frequent crashing or rebooting, physical damage to the board, and overheating issues that persist despite cleaning and maintenance.
For more detailed diagnostics, you might consult our troubleshooting page.
Important Tips and Warnings:
Ensure the device is completely powered off before beginning any work to avoid electric shock or damaging the components.
Always back up your data as replacing the motherboard involves removing all memory components, and data could be lost.
필요한 것
Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
Use a Phillips #00 screwdriver to remove the sixteen 3.6 mm-long screws securing the midframe.
Place a spudger or an opening pick under the connector's edge and pry straight up to disconnect the battery.
Use the Jimmy or your fingers to lift up the tape covering the front-facing camera.
Place an opening pick or a spudger under edge of the two press connectors and pry straight up to disconnect them.
Peal the tape up in the upper right corner of the phone to reveal the black coaxial cable.
To disconnect the black coaxial cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
