이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to fix your button pins if they are crooked.
필요한 것
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
거의 끝나갑니다!
결론
