주요 콘텐츠로 건너뛰기
OontZ Angle 3 Speaker Replacement
필요한 것
  1. OontZ Angle 3 Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 1개 OontZ Angle 3 Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 2개 OontZ Angle 3 Speaker Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: 3 단계, 이미지 2개 중 1개 OontZ Angle 3 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 1개 OontZ Angle 3 Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: 5 단계, 이미지 2개 중 1개 OontZ Angle 3 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: 6 단계, 이미지 2개 중 1개 OontZ Angle 3 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mason Hollander
회원 가입일: 01/20/16
1,604 평판
안내서 4개를 작성함
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G6
4 회원들
안내서 4개를 작성함
8가이드 댓글
Where do you buy replacement speakers?
michalfiona - 답글
Where do you buy the replacement speakers?
What type to buy?
michalfiona - 답글
where i buy the speaker replacement/
Sharina Uadan - 답글
Where can i buy the replacement speakers
Anil Meda - 답글
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 74
전체 시간: 9,412
