주요 콘텐츠로 건너뛰기
Oral-B White Pro 1000 Motherboard Replacement
필요한 것
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: 2 단계, 이미지 1/3 Oral-B White Pro 1000 Motherboard Replacement: 2 단계, 이미지 2/3 Oral-B White Pro 1000 Motherboard Replacement: 2 단계, 이미지 3/3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: 3 단계, 이미지 1/2 Oral-B White Pro 1000 Motherboard Replacement: 3 단계, 이미지 2/2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: 4 단계, 이미지 1/2 Oral-B White Pro 1000 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: 5 단계, 이미지 1/3 Oral-B White Pro 1000 Motherboard Replacement: 5 단계, 이미지 2/3 Oral-B White Pro 1000 Motherboard Replacement: 5 단계, 이미지 3/3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: 6 단계, 이미지 1/2 Oral-B White Pro 1000 Motherboard Replacement: 6 단계, 이미지 2/2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: 7 단계, 이미지 1/2 Oral-B White Pro 1000 Motherboard Replacement: 7 단계, 이미지 2/2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
결론
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
Hannah Parker
회원 가입일: 11/08/17
206 평판
안내서 1개 작성함
IUPUI, Team S5-G4, Baechle Fall 2017 IUPUI, Team S5-G4, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G4
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Motor are brushless?
joseferreira_ms - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 60
전체 시간: 2,786
