소개
Motherboard Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty operation. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some great soldering and desoldering tips.
필요한 것
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
