주요 콘텐츠로 건너뛰기
Orbo Jr. Battery Replacement
필요한 것
  1. Orbo Jr. Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
  2. Orbo Jr. Battery Replacement: 2 단계, 이미지 1/3 Orbo Jr. Battery Replacement: 2 단계, 이미지 2/3 Orbo Jr. Battery Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
    • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
  3. Orbo Jr. Battery Replacement: 3 단계, 이미지 1/1
    • Gently pull the cables attached to the speaker to remove it from the back cover.
    • The speaker is taped in the back cover and caution should be used when pulling on the wires.
  4. Orbo Jr. Battery Replacement: 4 단계, 이미지 1/1
    • Pull back the tape to expose the wires that are attached to the battery.
  5. Orbo Jr. Battery Replacement: 5 단계, 이미지 1/2 Orbo Jr. Battery Replacement: 5 단계, 이미지 2/2
    • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
    • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
    • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
  6. Orbo Jr. Battery Replacement: 6 단계, 이미지 1/3 Orbo Jr. Battery Replacement: 6 단계, 이미지 2/3 Orbo Jr. Battery Replacement: 6 단계, 이미지 3/3
    • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
    • Positive and Negative battery terminals.
    • Be careful to not make contact to other components on the motherboard while using the soldering iron.
결론
Ryan Christman
회원 가입일: 02/10/16
684 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-1, Sullivan Spring 2016 USF Tampa, Team 3-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 405
