필요한 것
Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
Now the fan and motor are ready for replacement. To reassemble your device, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
My blender would not blend smoothly. It use to make an unusually loud noise when I put the cup and start the motor. I realized the motor had a "play" making me believe it was not tightened enough. I took a look at the pics on this page and then realized it was assembled wrongly. The white rubber used to absorb the movement was placed after the motor was inserted. Thanks to all who have contributed to this Oster page.
Good day
i took apart my whole oster blender took the electric board out and all the button pieces came out. I have no idea what order they go in or how to put it back. There was a small spring that fell out as well as a Small plastic piece with 2 small springs in it. Can u please help?
