주요 콘텐츠로 건너뛰기
Oster 16-Speed Blender Power Cord Replacement
필요한 것
  1. Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 1 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 1 단계, 이미지 2/2
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Power Cord Replacement: 2 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement: 2 단계, 이미지 2/2
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Power Cord Replacement: 3 단계, 이미지 1/3 Oster 16-Speed Blender Power Cord Replacement: 3 단계, 이미지 2/3 Oster 16-Speed Blender Power Cord Replacement: 3 단계, 이미지 3/3
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Power Cord Replacement: 4 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement: 4 단계, 이미지 2/2
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Power Cord Replacement: 5 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement: 5 단계, 이미지 2/2
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Power Cord Replacement: 6 단계, 이미지 1/1
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Power Cord Replacement: 7 단계, 이미지 1/3 Oster 16-Speed Blender Power Cord Replacement: 7 단계, 이미지 2/3 Oster 16-Speed Blender Power Cord Replacement: 7 단계, 이미지 3/3
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Power Cord Replacement: 8 단계, 이미지 1/3 Oster 16-Speed Blender Power Cord Replacement: 8 단계, 이미지 2/3 Oster 16-Speed Blender Power Cord Replacement: 8 단계, 이미지 3/3
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Power Cord Replacement: 9 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement: 9 단계, 이미지 2/2
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 10 단계, 이미지 1/3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 10 단계, 이미지 2/3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 10 단계, 이미지 3/3
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Power Cord Replacement: 11 단계, 이미지 1/2 Oster 16-Speed Blender Power Cord Replacement: 11 단계, 이미지 2/2
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Power Cord Replacement: 12 단계, 이미지 1/3 Oster 16-Speed Blender Power Cord Replacement: 12 단계, 이미지 2/3 Oster 16-Speed Blender Power Cord Replacement: 12 단계, 이미지 3/3
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
  13. Oster 16-Speed Blender Power Cord Replacement, Power Cord: 13 단계, 이미지 1/1
    • You do not have to completely remove the circuit board to replace the power cord. You can, if desired, skip the steps of de-soldering the yellow wire, and the circuit board from the base.
    • De-solder the black wire from the circuit board, and then carefully remove the black wire.
    • Now you can solder on the new power cord.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Dana
회원 가입일: 04/14/14
779 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014 회원
CPSU-MANESS-S14S12G37
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 3,209
